Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
1941 Hood Spring Replacement #403228
02/08/18 03:52 PM
02/08/18 03:52 PM
MI, USA, Midland
Mike Buller Online content OP
Mike Buller  Online Content OP
MI, USA, Midland
I have been procrastinating replacing my hood springs. Those who have followed my 41 restoration know that a large wooden 3' dowel has been supporting my hood for several months. My past experience with hood springs is that the confined space they are in and the unpredictability of what might happen when dealing with a large spring is not for the faint of heart. While looking through the Chevs of the 40's on-line part catalog I saw they carried a tool to remove and replace hood springs. Tool Hood Spring. The tool comes with the following instruction sheet:Instruction Sheet.
Being frugal I asked a good friend with a lot of welding and fabricating experience to make me the tool. I used it to put my driver's side spring on. While I got it to work I did find it very clumsy to deal with, hard to remove with the spring in place, and I scratched my paint in a few areas. So I decided to try stretching the spring with a hydraulic floor jack, like shown in the Chevs of the 40's instructions, but placing 1/16" washers between each spring loop. When I removed the spring from the jack the spring was no longer straight but had a substantial curve to it. To remedy this I alternated how I installed the washers. I rotated what side of the spring each washer was installed on, so if I used 20 washers 10 were installed from the right side of the spring and 10 from the left. You need only enough washers to expand the spring TO about 14".
Hope this helps others deal with spring issues. If you have another way of dealing with the problem, please let us know.
Thanks, Mike
P.S. I used this method about 12 year ago but did not remove the washers for 6 months. When I went to reuse the spring it had stretched to the point it was no longer usable.
Attached Files IMG_1685.JPGIMG_1689.JPGIMG_1691.JPGIMG_1694.JPGIMG_1695.JPGIMG_1696.JPG
Mike 41/77 Chevys
Re: 1941 Hood Spring Replacement [Re: Mike Buller] #403231
02/08/18 04:30 PM
02/08/18 04:30 PM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
I used that method on my '57 years ago. Worked great except I had to use a pliers to pull out the washers.
Also bent spring sideways to open coils and insert washers.
Chevgene
Moderated by  AntiqueMechanic
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
3 registered members (Mike Deeter, Dave39MD, 1 invisible), 6 guests, and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
Dones475, aland, Stickdude, Achipmunk, centercut
15123 Registered Users
Forum Statistics
Forums69
Topics49,978
Posts362,414
Members15,123
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
