Posts: 1,739 Likes: 2
Posts: 1,739 Likes: 2 |
I am trying to identify a set of window garnish moldings I have. I believe they are 1927 or 1928 sedan. If anyone has either apart could they maybe check for the stamped number inside the molding and let me know number and location in window? I think I have a full set for fronts and rear for both sides. Thanks in advance.
Can anyone help identify? If anyone has extras could they check for the stamped numbers please?
Posts: 68 |
Where would the stamps be? and on which piece ( top bottom side) I'll be home tonight and I can try and see if there is any markings on them..
Steve
Hi Steve, Should be stamped on the edge that faces the glass on all pieces. Different numbers for different locations. They should start with an "A". Thanks.
Posts: 68 |
Drivers front door, 1928 National AB sedan. bottom A11792N. Sorry its the only one I can find that isn't still attached to the door. I have the rear quarter window out if you need those stamping as well.
Steve
Thanks Steve. I appreciate it. I got this set taped together with a load of 29 parts and I know they are not 29. I think they are a full set from a car so if I can find the number you gave I will know if it is 28 or not at least. If you can give the rear quarter numbers that would be great. No rush. Later,
Thanks Steve. At least now I know the mouldings are not 1928. Probably not 27 either. Looking at them and I noticed the numbers don't start with an "A" as on your 28 or my 29. I am starting to believe they may be much earlier. All have a five digit number starting with "9". Thanks again and Happy New Year.
Posts: 956 |
Cabboy, l sent you an email. Roger
Posts: 68 |
Glad you are figuring it out, Sorry for not getting back.
Steve
3 members (Rusty 37 Master, 2 invisible),
94
guests, and
23
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,077
Members18,308
