37Freak Offline OP
Hi!
My 37 Master is converted to 12V with a 1956 Chevy generator (12V;30Amps).
In the 1956 wiring plan a generator warning (idiot) light is shown.
Is this light necessary?
Old Bosch systems in my 30s and 50s Motorcycles need this light.
To get the Bosch generator going, a tiny field current must be supplied. This current is initially provided by the warning light. With the Ignition switch closed, current flows thru the lamp to the regulator and into the field winding. If the dash warning light is burned out or disconnected, the generator probably won't begin charging.
Maybe Delco 6V and 12V generators are better self-exciting at start-up then Bosch stuff. crazy
Thank you!
Tino
I have always found the idiot light is required on all systems to supply the field windings. This applies to alternators as well.
37Freak Offline OP
Thank you!
Is a 12V 2W bulb ok?
Tino
You need a standard type globe (not LED) and I would think a 2w would be very close to requirement, it only allows a small current to the generator field.
The warning light on generator systems is connected between the ignition switch and the armature terminal. When the gen is stationary juice flows from the ignition switch thro the lamp to the armature, being stationary it develops zero volts and current flows thru it to earth lighting the lamp.As it slowly revs up with the engine the voltage slowly rises and the lamp goes out.
You can substitute a resistor in place of the lamp (72 ohms , 2watts), and if you can ,mount it near the alternator,
37Freak Offline OP
At least, this is what I did.
http://www.lt-forum.de/dokuwiki/lib/exe/fetch.php?w=500&tok=06a77a&media=start:aus_umbauanleitungen:led-cockpit:led-anschluss_im_kfz-schema-ladekontrolle.jpg
Tino
Support The VCCA!
Member Photos
1964 Chevrolet Impala SS
by DreamChevy, February 17
My 1933 Chevy 2 Dr. Sedan
by 1939Chevy1, November 24
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
Who's Online Now
3 members (Peter_Gariepy, JEC51, triZero), 72 guests, and 31 robots.
Key: Admin, Global Mod, Mod
Newest Members
18,308 Registered Users
Today's Birthdays
aristech, RalphL, tonysk
Forum Statistics
Topics59,071
Posts429,069
Members18,308
Most Online1,133
Jan 22nd, 2020
