#401504 01/09/18 05:23 PM
Has anyone changed pin in Shift lever (floor shift) that goes thru round ball on the selector shaft,Can it be pressed out and new one installed? Mine is worn considerable.
robertst39 #401516 01/09/18 08:46 PM
On my 38, if I take the shift apart the pin will fall out if I turn it to the vertical.
old216 #401538 01/10/18 10:11 AM
Mine is in tight I will try Press on it.
