Posts: 106 |
Hi guys...I posted earlier regarding wiring questions. ..I have gennie questions...my gennie is model # 100460..serial# 7H19. .it has the cut out relay...the terminal pointing to the engine on the relay has a wire from the relay to the gennie...the terminal pointing away from the engine has nothing...the gennie has an "A" terminal on the gennie with no wire. ..if anyone could let me know where these two wires go to . I'll be in good shape. ..the cut out relay is a Delco btw...thanx a bunch Cheers Jimmy T 1931 Chevy Cabriolet
Posts: 29,848 |
Posts: 106 |
I did this because I just found the 6 volt forum...could be some guys are on here and not on the other and vice versa..i figured that if I had two posts going at once my chances of getting help on this matter would be greater...
Posts: 29,848 |
Topics59,071
Posts429,076
Members18,308
