37Freak Offline OP
Hi!
What is the difference between 37 (263543) & 38 (264275) pitman shaft for Master Deluxe models?
Tino
In short all major parts are different. Every thing was completely revised to different tooth contact., angle of teeth, angle of pitman shaft, etc.
1937 GA is all by its self.
37Freak Offline OP
Thank you!
You are more worth than the Spec.
Tino
