Posts: 239 |
There are 2 numbers on my Rochester. The number on the side is 7003536-13. The number on the bottom of the throttle body is 4478. I think the 7003536 indicates that it came off of a '52 Power Glide car. What does the -13 at the end represent? What is the 4478 number on the bottom determine?
Am I correct in thinking that it uses a #58 jet?
I would appreciate any help and also source of the information.
Thanks, Pete
1951 styline deluxe sport coupe w/54 engine and power glide
Posts: 239 |
After more research I found that the carburetor did come from a '52 Power Glide. The information that I found states that the jet should be a #57. The information on the '53 calls for a #58. Is this difference because of changes in the carburetor or the engine or both? What would be consequences of using the wrong one? The carburetor is on a '54 Power Glide engine.
Thanks again.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
The changes were in minor changes in the carburetor. You can run either jet and you will never notice any difference. If it were mine I woud run the #58.
Posts: 239 |
Thanks, Gene. I knew I could count on you.
Topics59,071
Posts429,077
Members18,308
