Had a new armature installed in my 943-J generator for my '29 Sedan. Went to install it to the sedan and found the pulley on the Generator was forward about a 1/4-inch in aligning with the fan pulley. Even though with slotted holes, I turned the generator mounting bracket to the engine 180 degrees. It looks to line up just fine now. I plan on tightening everything up tonight. Will see what kind of charging output I get then.
Bob
"When an old man dies, a library burns to the ground".
