regmudd Offline OP
Need advice regarding best way, and most practical way, to improve rear suspension on 1953 Sedan Delivery. We are going to to attempt to put a 2005 Corvette LS2 engine and transmission in front and need to do something with the rear end. My guy is not impressed with a 4 link setup so wanted to get some other opinions.
Thanks, RegMudd
use a XKE OR XJ jaguar rear independent suspension 1962---1986.. The mark X version is 61 3/4" wide . The S series 62--70 is 56" wide and the XKE is 53 1/2 .
Which should suit the width of the 53 SD ? Or lay down some large dollars for a KUGEL or a HEIDT IRS .
To match the IFS vette front you put in.
mike lynch parking
