#398290 11/15/17 04:55 PM
I just acquired a 1933 1.5 ton basket case. It came with 6 brand new 6.50x20 tires, 2 mounted on refurbished rims, 4 loose. Wondering what other years these tires and rims are correct for as I'm going to list them for sale in G&D and would like to get the year range correct.
Thanks for any input you can provide.
I might be interested in your tires....and wheels if they only go together.
I sent you a PM.
Lou Offline
Your rims fit 1931 second series "M" 1.5 Ton trucks thru 1935 trucks. In 1936 the lug pattern remained the same but the hole in the center was larger for full floating rear axle.
