Posts: 5 |
Vacuum Shift - is there a way to test - or instructions for rebuild? - Manual doesnt touch it , except for adjustment - ...Conversion/elimination kit: $150 - ...repair kit: $175
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Your post is puzzleing. Charlie
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
read this Read lubrication and washing. The leather seal is probably just dried out.
Posts: 96 |
To do a good job of cleaning cut screwdriver slots in the studs holding the body to the alloy end cap and valve holder. These are hammer in screws and can now be unscrewed. Pull the end cap out and clean the leather piston and body. I lubed mine with dubbin leather preservative. There are minimal parts in here so just note the order you pulled them out and reassemble the same way. Put in the lubricant before you put the cap back on and hammer home the screws again.
ColinGrant
Posts: 5 |
Ok, so it does cover it ... a little ...i think
& written in olde english !
