Page 2 of 2 1 2
Clement #396023 10/05/17 06:31 PM
It could be flooded due to all the failed starting attempts.
Let it sit untouched for a day and then try it pulling the choke closed for the first 3 seconeds of cranking over.
Did you forget to install the rotor?
Are the spark plugs sparking? Remove a spark plug and reconnect the wire . When you turn on the ignition and hit the starter you should see a spark jump in the plug gap with the plug grounded.
Chev Nut #396024 10/05/17 07:52 PM
Clement Offline OP
ok..rotor is in it. Will check spark. If I have no spark then what ? This will sound dumb...where does the spark come from anyhow ? What about the ignition switch ? If it is going bad how does that figure into the equation ?
Clement #396027 10/05/17 10:31 PM
While possible the ign. switch is about the last thing on the list to prevent starting. If you have power at the coil when the switch is in the on position the switch is OK.
Checking the spark plugs for sprak will will narrow the problem down. If there is spark and gas the engine should run.
Chev Nut #396030 10/06/17 08:11 AM
Clement Offline OP
I see. ok thx !
Clement #396031 10/06/17 08:50 AM
Clement Offline OP
Pulled # 1 spark plug and reattached wire. set on top of valve cover. Put a mirror ifo so I could see reflection of spark from driver seat. I cranked the engine for about 4 to 5 seconds at a time for 4 times. Got spark for about 2 seconds of that time. Now what ? Thanks.
Clement #396046 10/06/17 04:43 PM
This is like to diagnose a medical condition over the phone.
Have been giving this more thought. You mentioned, could the ignition switch be bad....After thinking it over the actual switch may be fine but if the car has the original eletrolock(cable enclosed switch wires) the wire inside the armoured cable may be shorting out.
My test would be remove the wire from the coil and run a new wire from the battery cable connection on the starter to the coil. This will by pass the cable wires. If the engine starts them problem is inside of the cable.....problem-to shut off the engine off the wire will need to be DISCONNECTED.
Chev Nut #396050 10/06/17 05:17 PM
Clement Offline OP
Yes it is crazy with all this diagnosing !!! Yes...it has the original electrolock. Ok...I can try that test...so you are saying if this test works, to shut off the engine I need to undo the wire ? ( because it isn't hooked to the ignition ) Then I can run a new wire through the electrolock cable and everything should be ok ? haha Thanks !!
Clement #396051 10/06/17 05:35 PM
Clement Offline OP
I had another thought....I can undo the wire and pull it out of electrolock cable and see if any bad spots and/or just replace it.
Clement #396052 10/06/17 05:42 PM
The Electrolock is a whole project unto itself and is not quite as easy to replace the wire as it may initially appear.
Try Gene's method to bypass the electolock and go from there. You will need to disconnect the replacement wire to shut the engine off if it starts.
canadiantim #396060 10/06/17 07:51 PM
Clement Offline OP
Ohhhhhhh...great..ok well how do I disconnect that replacement wire without getting shocked ?
canadiantim #396062 10/06/17 07:52 PM
Just keep up your SPRITS and make belive that you are hunting for a GHOST....... haha
Check his profile for that one.
Clement #396063 10/06/17 07:56 PM
There is not enough current to give you a shock.
The spark plug high tension wires will do that.
Chev Nut #396065 10/06/17 09:16 PM
Clement Offline OP
Ok...that's good !! Thanks...will have time Saturday afternoon to do this hopefully. Will keep you posted.
Clement #396107 10/08/17 12:12 PM
Clement Offline OP
Ok...that didn't work. The only think not tested yet are coil and condenser. I am at a complete loss here.
Clement #396150 10/09/17 09:05 AM
Clement Offline OP
Now I have a whole new issue...went out Monday morning to undo all the " test and bypass " wires...the coil was so hot I could hardly touch it.
Clement #396154 10/09/17 10:19 AM
This indicates that the coil (ignition) was not "turned off" .
This could also have caused the points to burn also if they were closed..
Chev Nut #396168 10/09/17 12:51 PM
Clement Offline OP
ugh I took off all the" test and bypass " wires...it's ok now...finally cooled...will test condenser later on...if anybody has any helpful ideas I will take them...I know you are all tired of me by now...
Clement #397319 10/27/17 05:20 PM
Clement Offline OP
I gave up, had car towed 2 blocks to a nice old fashioned repair shop by my house. Both the original coil and the NORS coil I bought on ebay were bad. Plus I screwed up when I installed the points. Did something weird with the spring. They have a nice 6 volt coil on it, purrs like a kitten. Eventually will get one like original. That is all. Thanks.
Page 2 of 2 1 2
