I'm (still) in the process of restoring my '67 Camaro and will be adding factory air conditioning to it. I see that the a/c hoses from the condenser get routed back to the engine compartment through holes in the wheel well/skirt. The assembly manual shows a "sketch" of where the two holes should be drilled (C60 D3). The exact location is not real obvious to me. Does anyone have a better diagram or photo of where the holes and grommet are located? Thanks!
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
Wilwood Engineering1955-1957
You need to get a copy of the 1967 Accessory Installation Manual, it should have all of the information you will need
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
Thanks, John. Does anyone out in VCCA land have one of these 67 manuals they'd like to sell? I did a quick check of eBay and Google and got no hits at all.
Dale Carter
VCCA #8661
1967 Camaro Coupe
If you where doing the dealer installed under dash air ours has it and Dad has an nos GM still complete in the box that still has instructions in it I believe for our 67 Camaro conv.
33yr member/3rd generation member
Andy Jurski #42092
Family collection:
26 collector cars:
20 Chevrolet's
2 Ford
1 Oldsmobile
3 Pontiac's
Thanks, but sorry, no. Going with the factory a/c install.
Dale Carter
VCCA #8661
1967 Camaro Coupe
