Posts: 1,125 |
Are the ignition wires on a 1955 Bel Air supposed to be with straight boots or angled boots for the spark plugs? Are the boots black or a reddish orange color? Thanks, Sid
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I don't know the answer but it might help if you specify if a 6 or 8 cylinder and a car or truck.
Black angle boots. Correct wires available from Danchuck - #1400 for $84.95.
Posts: 1,125 |
Thanks Gene. In answer to Steve it is an 8
As I posted I did not know the answer but from Gene's post they are apparently the same.
I knew he had an 8 culinder from previous posts.
Posts: 1,125 |
In reading the Danchuk catalog it appears that reddish orange boots were used on late 56 ignition wires.The reason for my question was that I had just received a set of wires that had the orange red boots on them. I could send them back, but I wondered if I might just paint the boots black with a black bumper paint? I have painted ignition wires before with lacquer, but they were not rubber wires. What are your thoughts? Would the paint stick to the rubber boots? Would it blister off with heat? Sid
I doubt if anything would stick to the soft stretchie rubber.
Posts: 1,125 |
The vendor agreed to take them back. This afternoon a friend came by with a correct set he had tucked away. Thanks for the help guys.
