I just bought a spark plug socket (double end) but it doesn't fit the plugs I got from the Filing Station (which are correct for my 32 4 dr. Special). The ends are 1 3/16 X 1 1/16 OD and 1 1/16 X 1 ID. Apparently it isn't the correct tool. Can anyone confirm? Thanks for any help.
Support The VCCA!
The correct plugs for your 1932 are AC G-12 if early or AC G-10 later. Replacement plugs are likely what you got from the Filling Station. They will use a modern spark plug socket not the larger one used with the G plugs.
Thanks Chipper. I was going to keep the spark plug socket as part of my OEM tool kit if it is the correct one.
