Posts: 234 Likes: 5
Posts: 234 Likes: 5 |
Aren't there supposed to be washers under the screws that hold down points and condensers? There are none on my 40. Seems like there should be.
Posts: 1,294 |
Never seen washers on the hold down screws. But yes on the wire screw.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I have only seen metal washers on the fixed point (to lock down the adjustment) and condensor, these parts need a good earth. The moving point should be insulated from the rest of the distributor, the other end is connected to the coil negative terminal. Tony
