I have a 63 Impala with a 327, It has been converted to a 1 wire alternator and the original wiring has been hacked. I am having a draw off of the horn relay and it keeps killing the battery. Does anyone know the proper way to bypass this relay? I am told it feeds power to everything. They completely cut off the wires for the voltage regulator. The horn relay has 1 wire from the battery, 2 wires going to the ignition switch (always hot), One wire going to the horns, and 1 wire going to the column. Any help would be greatly appreciated.
