Posts: 84 |
Hello,
the door opens fine when using the inside handle but sticks when using the outside handle. Its like the button isn't pushing the release in far enough. Is there an adjustment I can make?
No,,,,but try lubrication.
Posts: 84 |
No,,,,but try lubrication. Its lubed I pulled the handle and the rod on the button is pretty worn. I am going to replace it. Thanks
