Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
Thanks, Mike. I did find the steel cam gear in my stash and it looks pretty good.
Eventually, I will have four piles of parts from the three engines I'm tearing down now and some parts from my 25+ year stash of rusty gold.
For now, I am eyeballing the parts in a general way, but will evaluate the parts in the four piles closely when I need to do the final build.
Stay tuned! It'll take a while, but I am having fun! Dean
The next parts to come out of the second engine is the oil distribution system. Notice in the pictures that there are copper washers under all the bolts and fittings that go through the block, thus sealing oil leakage opportunities. The first picture is of the existing oil lines where they connect to the oil filter (not shown). For reference, the two 5/16 inch holes in between the tube fittings are for the oil filter bracket. The second picture shows where the oil tubes meet at the junction above the oil distributor. For reference's sake, the bracket shown in the photo is for the arm that moves the spark distributor retard/advance push rod. Cheers, Dean
Here is the oil distributor and the oil trough feeder tubes inside the engine. After all the brackets and holders are disconnected from the outside of the motor, this whole assembly lifts out. The second picture is a closeup of the bracket that holds the end of the trough feeder tubes in place. A square nut and split lock washer is used in this spot. The bracket holds the nut so that it will not turn when tightened. Cheers, Dean
Here is a picture of the oil trough feeder tube bracket bolt heads that show on the outside of the engine block. Notice the copper washers under the bolt heads. For reference's sake, the hole in the middle of the photo is for the dip stick. If you have trouble imagining this, stand on your head. The engine is upside down in the engine stand. Dean
At some point in time that engine needs a good Saturday night bath.
Right you are, Ray. I will 'bathe' the pile of parts that will go into the final build engine. Certainly its innards. Lurch wouldn't be happy if the outside was too purty. Cheers, Dean
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
Posts: 3 |
HI Dean,
Nice work with the resurrection so far.
I have some food for thought in regards to any machining you might be looking at getting.
One of the modification that we have conducted on the old mans 1925 chev is to counter sink the flywheel bolt holes. This allows a modern day clutch fit in quite nicely.
[img:left]http://vintageandveteranchevy.blogspot.com.au/2017/04/blog-post.html[/img]
Also another modification we have adopted from advice is to install a lube line from your main oil pump line directly into the bottom main center cap.
[img:left]https://vintageandveteranchevy.blogspot.com.au/2017/04/centre-cap-modification.html[/img]
Thanks Chistech and Brendank. When I get to the final assembly, I will make a list of which parts are coming from which engine and also list any modifications that I make. Keep these good ideas coming! Below are the pictures that didn't work in the previous post. Cheers, Dean
Posts: 12 |
This is a really interesting thread, apologies if my post constitutes a hijack... Also another modification we have adopted from advice is to install a lube line from your main oil pump line directly into the bottom main center cap. That's an interesting mod, I'm building a slightly "warmed up" motor for my '28 Tourer at the moment. Did you put grooves in the white metal on the underside of that oil feed, or did you just leave a hole to feed the oil?
Posts: 42 |
That's not a 1925 Chev oil pump... The 1925 had an external oil pump with inlet & trough oil lines through the pan, the centre main was fed through the block. You must have a '27 or '28 engine in your 1925 Chev.
I agree with Termite_Delight that BrendanK's car might be a '25, but the engine is from '26, '27, or '28. Although the installation of an oil line to the main crank bearing is an interesting modification, there is an aspect of the the oil distributor that is not mentioned much. In addition to feeding oil to the trough filler tubes, the oil distributor has a hole on its side that squirts oil directly into the oil reservoir that oils the center crank bearing. You cannot visually see this hole unless you take the oil distributor out of the engine. Here's a thread where I wrote about a test of the new gear-type oil pump for the four cylinder engines. In the video, note the stream of oil coming out of the side of the oil distributor. This is the stream that feeds the center crank bearing in the later 4 bangers. 1928 gear oil pump test In the engine that I am currently tearing down, this hole is complete plugged with sludge, meaning the center bearing was NOT getting the flow of oil that it wanted or deserved. Dean
Posts: 3 |
HI Termite and Dean,
Yes you are correct this is a 27 engine we are building right now. Also the old mans 1925 Tourer has a 1926 engine installed.
Dean interesting about the oil feed from the oil distributer I have not noticed any holes or paid too much attention as the oil line modification was going to be done.
Regards Brendan
Posts: 3 |
Hi Stuart,
The white metal is the same as standard with the X grooved in the cap.
Regards, Brendan
Back to the tear down. The picture below is another clue that this '28 engine was put into a 1924 car. The casting date on the flywheel is from 1924. Dean
The crank pulley came off with a little heat from a propane torch and a gear puller. Then, I took off the cover over the cam gears. The next operation, removing the cam shaft and crank-cam gear, require that the crankshaft not turn. It's hard to screw in a gear puller when the crank and camshaft turn easily! What do ya do when the tool you want does not exist? Invent it! Behold, my patent-pending keep-the-crankshaft-from-turning-by-jamming-the-flywheel sheet metal bracket. The royalty fee for using my idea is one Diet Coke. Cheers, Dean
Next to come out of the engine is the camshaft. It is held in place by two slotted flat head 1/4-20 bolts. You can see them through the holes in the cam gear. The previous person who touched these bolts center punched one edge to keep them from getting loose. So, I used an old school impact wrench to loosen them. The last time I used this tool was in the late 1970's when I took a '69 Honda 750 apart. Notice the gear puller on the crank cam gear. That sucker was STUCK!!! It did not come off after a week of soaking in PB Blaster and heating the gear with a propane torch. What finally did it was to heat the gear again and melt some wax on the end of the shaft, which lubricated the shaft by capillary action. This is a trick I learned recently from the local High School Auto Shop Teacher. The next picture shows the bracket that holds the camshaft in the block. This picture is showing the back of the fiber cam gear. Cheers, Dean
Slightly out of order, I had to remove the crank pulley woodruff key before taking off the crank cam gear. Below is a picture of the setup. I clamped a vice grip onto the part of the key that was outside the crank. Notice that I put 2/3rds of the vice grip on the key and 1/3 hanging out in space. This was to provide a place to pound a wedge (screwdriver) into so that the key was 'persuaded' out of its groove. Cheers, Dean
Next to come off was the backplate that resides behind the cam gears. Below is a picture of the slotted flat head 1/4-20 bolts that hold it to the block. I used the impact wrench again to loosen these bolts because, as you can see in the photo, the previous guy center punched the edge of each bolt to keep it from coming loose. Cheers, Dean
With the cam gears backplate removed, you can see all the yucky sludge that clogged up the oil flow cavity. Nasty stuff! The second photo shows the cavity with some of the sludge scraped out. At this point of the story, I'm going to take a short break. I have to pull Lurch's engine out and get it on the engine stand for its teardown. So far, I did not talk too much about evaluating parts for the final build. I will do more of that after I take Lurch's engine apart. Stay tuned, Dean
Let the fun begin again! I finally pulled Lurch's engine out and will now start pulling it apart. To recap the reason for this entire thread, Lurch's engine was running, but smoking and with little power. The poor guy could hardly get on and off the trailer! The compression was 50-55 pounds in each cylinder. So, I'm tearing apart two partial '28 engines and Lurch's '28 engine to hopefully get a full complement of parts for a good used engine. Ever onward! Below are the first pics of Lurch's engine. I expect to find a lot of wear, but clean innards. We shall see. Cheers, Dean
Just a little out of order, I pulled the pressure plate off before I put the engine on the stand. I took two opposite bolts out and replaced them with two longer bolts. Then I took out the rest of the bolts, the pressure plate slide safely away from the flywheel, and out onto the longer bolts. Then clutch dropped out. Dean
Here are a couple of pictures of Lurch's head. The top looks good, but I know from experience that the rocker bushings are very worn. There is a lot of carbon buildup on a couple of the exhaust valves. I'm not surprised. BTW, what are ya gonna do when your son moves out of the house and leaves his skateboard? Re-purpose it!! Cheers, Dean
Can you spell WORN? Yes, this engine was running last year. Here's a picture looking down in cylinder number three. I'll quantify the wear when I inspect everything to choose parts for the final build. Dean
Next to come off the engine is the oil filter and coil assembly. Since a new oil filter is around $100, I put a 1950's style canister-type oil filter on Lurch. The cartridges are $15 at Napa. This type of oil filter canister was originally bolted to the intake manifold. I used a short section of one inch galvanized water pipe that is bolted to a piece of angle iron for a bracket. I cut a slot in the water pipe to access the bolts that hold the whole thing to the block. Below is a picture of the bracket. Rube Goldberg strikes again! Then I took the distributor out. This is the correct distributor (Delco 635B) for '28 engines, so I'll reuse it for Lurch's build. The driving gear is worn (the teeth are thin), so I'll probably replace it. Cheers, Dean
2 members (Peter_Gariepy, 1 invisible),
78
guests, and
34
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,069
Members18,308
