#382699 01/25/17 07:03 PM
In the February 2017 issue of the G & D, there is an article about a 1960 Impala, pages 24 and 25.
The article makes reference to finding a "rare 1960 Impala".
At the end of the article, the owner states this 1960 Impala had the "rare 3 speed automatic".
I'm not aware of a 3 speed automatic in 1960.
Anyone have information on this ?
Wilwood Engineering1955-1957
I saw this also. I am sure he is refering to the Turboglide transmission. It was the only "automatic" available with the 250 H.P. 348. Chevrolet refered to it as "Tripple Turbine" in some of their literature as the plantary gears put it through three different phases in the torque converter. All gear reducton was done through the converter turbines and no shifts were felt. If you could listen carefully you could hear a slightly different planet carrier gear noise change from step to step. Owners complained because they couldn't feel a shift like the CVT's of today.
The 1957 and 1958 Turboglides were very problematic.....The new and improved 1959-1961 were as good as any automaic in its day, just that a lot of techs didn't like to work on them....or didn't know how. You know how that goes curse
The T.G. worked best behind a 348 engine because it required more torque. In 1959 the T.G. got the 3.08 axle ratio so at least the highway milage would be satisfactory.
Glad you mentioned ths. I was thinking of putting a "correction" in the G&D but that would not be proper.
Note-in 1957 the TG was available on any 283 with a hdraulic lifter cam, 185,220,245 and 250 HP.
In 1958 you could get the 250 HP 348 with P.G. or T.G..'59 and up the 250 HP was available with TG only.
From 1960 and up a P,G. was available in a special police 348 305 HP version with a 3.55 rear end.
Great information! Since the above is about a 1960 Impala it should also be posted in the 1958-60 forum so that others interested in that era will see the information.
OOPS, JYD,
I thought I did.
Can we get a moderator to move this thread to the 1960 Forum ?
If a moderator does not move the thread you can re-post it in the correct forum.
Yes, it's reposted under 1960.
