#38271 01/30/02 09:40 PM
Mudbug Offline OP
I am trying to determine if a starter from a '63 292 will fit a '56 ?ci. I know I wont be able to keep the pedal start( I wish I could though), but I dont know what else to do.Can anyone help ?
Thanks,
Mudbug
Wilwood Engineering1955-1957
#38272 01/31/02 07:56 AM
HI Mud,
Based on your post, I take it that the original starter has gone to Chevy Heaven.
If you need assistance with a "rebuild" to correct factory performance and appearance - let me know - I can set this up.
The 292 is a newer casting block and the starter will not work on the '56 engine block. The nose, armature, and solenoid are considerably different (which I am sure you know).
Oliver J. Giorgi
1958 Passenger Car
