#372908 07/31/16 09:05 AM
sod Offline OP
Greetings, Im stuck. Can someone help me with a power steering bracket problem? I have a extended water pump and a lower PS pump bracket that fits, but cannot seem to get the upper bracket.
Any advice with a part # or other suggestion. Thanks
Wilwood Engineering1955-1957
sod #372911 07/31/16 09:54 AM
Are you using the 1969 & up brackets? It kind of sounds like you don't have the 68 brackets. What body style also?...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
