Posts: 72 |
Hi there guys, quick question for you all. Just bought a set of wrap around for both the front and back bumpers but they come with no bolts. Anyone have any idea where I can buy some and what size they are. Currently I have four straight single guards on each bumper so I don't think I'll have any bolts once I remove two from each bumper. Thanks again in advance.
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
Most auto parts stores carry bumper bolts. see bolts
Posts: 72 |
Posts: 3,578 |
Soccernut.....Are you referring to the accessary bumper tips??
Hi Bruce, I believe that's right. The way I read it is he had FOUR bumper guards on both the front AND back bumpers. Bet that looked weird.
Posts: 72 |
Chef-chevy, yes the wing tips are what I got. If you look closely at my picture you can see how it looks now.
Posts: 3,578 |
Nice score on the front bumper guard....your wing tip has a clamping system which tightens around the end of the bumper...Are you missing those nuts and bolts??? a larger pic of your car
Posts: 72 |
So just got them in today and did not know about the clamp on each of them, they are intact just needing the bolt to hold it to the bumper.
Posts: 3,578 |
The reason I mentioned this is when I got mine many years back the bolt on the clamping system was badly stripped and the only way I could remove it was to cut it off...I had to kind of rebuild them, for fit,prior to plating
Posts: 3,578 |
This is why I had such a problem removing the bolt
Posts: 59 |
Doesn't Chevs of the Forties have them?
Posts: 3,578 |
I think they are back ordered...Not the COT40's they use to be
Posts: 72 |
Back order. Had to go to lowes to get some. Not proper but will do the job until I get some.
Posts: 72 |
Bumper bolts back in stock!!!
