Page 2 of 2 1 2
Gene and others have pointed out that the Huck was used through 1950. Then they went to Bendex in 1951.
Thanks, Charlie. Many parts websites stop at 1941 or 1948...
~Jim
'38 Master Deluxe 2-Dr
*Disclaimer*...All technical advice given is for entertainment value only, and is not to be taken seriously...
Hi Rick,
I only know how to post pictures through Photobucket's website. You can find what it's about by looking at my pictures. Photobucket
Good luck, Mike
What do the springs on the parking brake rods do? Mine does not have any on and the brake seems to work OK
ColinGrant
Originally Posted by Fleet47Master
Is there any way to insert a picture into a post other than using a picture hosting site?
Most forums require external linking...photos take up a lot of memory. If you sign up for Outlook/Hotmail/Gmail, can use the free OneDrive app on your phone to get quick links.
~Jim
If I had to guess, those springs would prevent the rod from rattling around while the brake is disengaged.
~Jim
Here is the missing spring (brake shoe return spring) that attaches to the top of each brake shoe. The picture I posted above did not have it installed. Notice the black plastic tie I was using on the brake cylinder (wheel cylinder) to keep it from leaking while I was installing my brake shoes.
[Linked Image from i1321.photobucket.com].
Thanks Mike
P.S. Colin I would get a replacement spring for your emergency brake.
Page 2 of 2 1 2
