I'd like to hear from owners of unrestored '61 to '64 Impala Sport Coupes and convertibles to ask questions about the cardboard panel installed behind the rear seat back. (viewed from inside the trunk)
I'd like to know if the panel has holes punched in the center or not and if the car originally came with a rear seat speaker. I'd also like to know if the panel has trunk spatter paint on it or not.
Please let me know the year, model and assembly plant. This is for an ongoing research project.
Verne patriot
Wilwood Engineering1955-1957
Vern..I bought new Oct 63 delivery..Impala SS Coupe…no splatter on cardboard like it was put in place after spars were splatter-sprayed…4 holes in center section of cardboard…2 about 1 inch wide vertical separation about 1/2 inch…bottom hole about 2 in above base horizontal spar…they are maybe 1.5 to 2 in in vert height…located right bottom area of center section…another about 1/4 wide and 1 inch vert height ..center section above other two I described…1/2 in from top horiz spar…another in right side opening 1/4 in wide by 1 in vert length 1/2 in tom rs spar…last one is in center section to left of holes first described and same size as first 2 described about 4 in from center/left spar…all views looking from inside trunk..pics? can't get enuf light! send email if not clear..Billu38
Vern…that was a 64 Chevy SS Coupe…Tarrytown…327/300HP 4 speed…Bill U38
I should read more closely….YES…came with factory speakers in rear seat..Billu38
Thanks Bill. If you could, please send me a photo through email. Set your camera to it's highest resolution setting.
Verne
I'll work on it Sat….my photography skills STINK! More tomorrow…Billu38
My 62 has been in the family since 1970, and the trunk has not been touched. It has the holes and had no rear seat speaker and is painted with spatter paint, as well as the body harness. My two door sedan was painted also.
Thinking about how the body was built, the panel would have to be painted. The paint process would have been complete prior to interior any installation, and the panel is installed over the body harness, and my harness is covered with spatter paint. One would think that the panel prevents the spatter paint from entering the cabin. If the cardboard was not painted then how come the vertical supports in the trunk are painted, and I had never seen any overspray of spatter paint in the cabin area.
The car is 07A Tarrytown. I had taken photos if you are interested
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
John,
I have data that shows that some plants installed that cardboard panel before AND after spatter trunk paint. It's just a plant procedure deviation that I'm trying to nail down. I'm also trying to nail down whether the panel always had the holes on Sport Coupes or just the ones that came with a rear speaker.
Verne
I would be very interested in hi-res photos of it.
I'll bet the 2dr sedan doesn't have any holes in the panel though...
PM me your email I don't know if I still have it. I will have to dig for the photos on the sedan before I did it, I do know it was painted also. That too is a Tarrytown car 04B. I don't recall if the holes were there off the top of my head
I would say the holes were on all, don't forget I would say a majority of the radios and rear speakers was a dealer installed item. My car does have the holes an no rear speaker
John
Definitely NO SPATTER on my cardboard in the Tarrytown 64 SS Coupe….all original and never touched..photos this morning…Billu38
Vern…sent photos to your e-mail this AM…Billu38
Photos received. Many thanks. I would like to hear from more members if possible.
Verne wink
Verne, I have owned two 62 Impala sport coupe models. Currently have one. Both had no rear speaker, and had the holes in the cardboard with no splatter paint and both had splatter paint trunks. I added rear speakers to both. Bob
This was a project Verne was working on, unfortunately he had passed away about two years.
John
Good evening all. I also have some question regarding 64 Impala SS. Many new discoveries were found on my car as it getting restored. It is believed my car was in fact a true 425 / 409. I wanted to compare some photos I acquired with someone that owns a 425 / 409 that came from the LA plant.
