Posts: 52 |
It has been a couple of years since I last made a post here but I am still in need of answers as well as photos, charts, diagrams of the unusual and unique '40 Cabriolet chassis frame. It is a bit puzzling why Coyle (Chevy head then) would allow such a one year only, one car only with new tooling, pass by him? And was not even a design similar to any other vehicle in production then? And had plenty of lead time to come up with something that worked better since there was no '39 Convertible. Any help is greatly appreciated to help with my book research!
Eric
Posts: 2,037 Likes: 5
Posts: 2,037 Likes: 5 |
1940 Chevrolets have many one year only designs and parts. The frame on a 1940 is a one year only frame as some other years of Chevrolets were back in the days. 1940 did however use all of the same parts for the front knee action suspension. When Chevy tried to improve from year to year, often times the vehicles were built 2 inches longer or 2 inches wider. This affected the design of the frame. Then from 1941-48, Chevy did decide to keep a number of parts very similar or the same. 1946, 1947 and 1948 were obvious to stay the same due to the ending of WW II. After the war, new cars were so much in demand, that the manufacturers didn't worry about always coming up with a new design or a new frame. For example, all 1941-1948 passenger rear fenders are the same, except for the mud guard holes.
dtm
He is refering to the odd 1940 convertible frame.....looks like something from a tank. The 1941 and up convertible frames were more or less a stock frame with a common X in the center. Who ever designed the 1940 frame could not stop adding braces and members.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Eric, The lead time was taken up on perfecting the 1941 Cabriolet. Note: There was indeed a 1939 Chevrolet Convertible/Cabriolet. It was produced by the GM's Holden Division of Chevrolet in Australia. (Ownership of the critter is somewhat vague.) I know this because recently I made the mistake of mentioning on Chat that there was no 1939 cabriolet/convertible. Immediately thereafter I thought the wrath of God had descended on me. I was blooded by a thousand cuts, mostly from Down Under  . Mates they were not. Bunch of Tasmanian Devils they were. Worse fate than if I had waded into a piranha filled river with a bucket of Colonel Sanders fried chicken tied around my loins. Was too! Best luck on your quest, Charlie
Posts: 52 |
He is refering to the odd 1940 convertible frame.....looks like something from a tank. The 1941 and up convertible frames were more or less a stock frame with a common X in the center. Who ever designed the 1940 frame could not stop adding braces and members. Yes, it looks like this:
Posts: 52 |
Top view of one being modified but bracing still in place: ![[Linked Image from forums.aaca.org]](http://forums.aaca.org/attachments/f169/278926d1414955180-1940-chevrolet-cabriolet-question-3127847856_c6e729dc9e_z.jpg)
Posts: 52 |
Eric,
Note: There was indeed a 1939 Chevrolet Convertible/Cabriolet. It was produced by the GM's Holden Division of Chevrolet in Australia. Yes, indeed there was and I am in correspondence now with one owner asking what its chassis looks like in case the 1940 American version was derived from it. He said the 1939 Convertible (Roadster they called it) was the only one to have X type bracing that year. Eric
Posts: 52 |
Eric,
Note: There was indeed a 1939 Chevrolet Convertible/Cabriolet. It was produced by the GM's Holden Division of Chevrolet in Australia. Yes, indeed there was and I am in correspondence now with one owner asking what its chassis looks like in case the 1940 American version was derived from it. He said the 1939 Convertible (Roadster they called it) was the only one to have X type bracing that year. Eric As of yet I am waiting on a photo of the 1939 Cabriolet frame but from what he is describing it looks more like a traditional X along the lines of a 1939 Pontiac but instead of C channel raild it used welded I beams and had a torque tube.
Posts: 3,620 Likes: 5
Posts: 3,620 Likes: 5 |
Was all of the X bracing just attached to a regular passenger car frame, or were the side rails and cross members different as well? If it was just the X bracing, It's not that much of a difference… just added parts. Those parts may share stuff with Pontiacs and export stuff from Canada as well.
Weere any convertibles produced in Canada in 1940?
Not sure… I thought all of the chassis for the Holden bodied cars assembled in Australia were from Canada. I could be wrong.
Posts: 3,136 |
I would appear the "modified" version was built to get you where your going a bit faster...With a bit more wind in your hair...lol
Posts: 52 |
Weere any convertibles produced in Canada in 1940? Yes. Chevrolet has been made in Canada since 1915 and the model number for the Convertible: 401067 They varied little or not at all from the US counterparts.
Posts: 52 |
Was all of the X bracing just attached to a regular passenger car frame, or were the side rails and cross members different as well? If it was just the X bracing, It's not that much of a difference… just added parts. Those parts may share stuff with Pontiacs and export stuff from Canada as well. None of the bracing used on the 1940 Cabriolet was shared by any other GM car.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Not sure… I thought all of the chassis for the Holden bodied cars assembled in Australia were from Canada. I could be wrong. Correct Brewster. Not sure if they were shipped here as chassis rails and then assembled with all cross members , or shipped as a riveted together chassis and then mechanicals added , then the bodies.
JACK
Posts: 52 |
Not sure… I thought all of the chassis for the Holden bodied cars assembled in Australia were from Canada. I could be wrong. Correct Brewster. Not sure if they were shipped here as chassis rails and then assembled with all cross members , or shipped as a riveted together chassis and then mechanicals added , then the bodies. Jack, your 1939 when you get a chance would like to see its own unique X (even if just a shot looking under the car on the ground). Here in the states the "roadster" was not offered in '39 but I do wonder if the '40 in Oz also had the oddball chassis too and not a carryover of your '39? Also to add to the earlier post, the base side rails were uses for the convertible but the front cross and reinforcement braces were changed out and the heavy cross beam and non aligned legs of the "X" which looks more like K's.
Posts: 52 |
Not sure… I thought all of the chassis for the Holden bodied cars assembled in Australia were from Canada. I could be wrong. I am not sure if the Chevys in Oz were referred to as Holdens then? The brochures only show "Chevrolet".
They were Chevrolets. Holdon was the company that built the bodies. GM owns shares in them. Much the same as when they owned shares in Fisher body in the USA.
Posts: 52 |
They were Chevrolets. Holdon was the company that built the bodies. GM owns shares in them. Much the same as when they owned shares in Fisher body in the USA. I understand but normally the Holden bodies are unique (at least in later years) and listed under that marque while these 1940s are the same American designed bodies and only listed as Chevrolets in Australia.
Holden stopped making the Chevrolets, and focused on their own entire car in '53 I believe. Up until then, they made the bodies and dropped them onto Canadian made chassis and engines, and installed Canadian made front clips. (hoods, fenders, grilles). For '49-'52 they may have used US made body dies, as I think the Bodies were pretty much the same, just right hand drive. One of the Aussies will know better then me though...
Posts: 271 |
Holden cars went in to production in 1948 and Chevrolet then used Fisher bodies, the only exeption being the coupe utility which continued until 1952. The chassis x member on the 1937 to 1939 toures and roadsters I believe was made by Holdens as they found out early in production that the open cars had too much scuttle shake. Some early 1937s dont have the x member. It is quite different to what the American 1940 cabriolet used. No open Chevrolets were made in Australia after 1939.
Posts: 52 |
The chassis x member on the 1937 to 1939 toures and roadsters I believe was made by Holdens as they found out early in production that the open cars had too much scuttle shake. Some early 1937s dont have the x member. It is quite different to what the American 1940 cabriolet used. No open Chevrolets were made in Australia after 1939. Do you have a picture or diagram of the 1937-1939 open models? Or another car that had a similar design?
Posts: 271 |
On page 57 in this section a small part of the x member can be seen in a post by 1937 roadster.
JACK
