Hello Everyone,
In the process of replacing the rear springs. The rear mount on the frame is a screw style. There is slop between the inner screw and the outer screw (pressed into the mount).
Has anyone ever attempted to remove the pressed in part of the screw ??
I tried a home made puller, but it wouldn't budge. I'm thinking of using oxy/act to add heat.......would anyone have a real era correct tool that I could rent ??
Any advice would be great.
VCCA # 047832
