Hello All!
I am here looking for some help. I need to make sure I remember how my coil is wired correctly. On the positive terminal of the coil I should have the ignition wire, wire from the side of the distributor away from the block and external condenser. Then the negative side of the coil should have a wire running down to the side of the distributor closest to the block. Correct?
Where may I purchase a replacement condenser, is it the same as the on inside the distributor?
thanks for the help guys!
