#315604 08/13/14 04:51 PM
mark38 Offline OP
Hi can you tell me if special bolts are needed to install 38 cowl vent. Thanks
Become a Member!
Hello mark38,
I had recently replaced the the gasket under my '37 cowl vent and the hardware was 1/4-20x1/2 inch, the head is large and single slotted with a lock washer and square nuts. I replaced mine with hex head bolts and added flat washers to the nut side because of the slot on the bracket.
VCCA # 047832
