Posts: 4,373 Likes: 30
Posts: 4,373 Likes: 30 |
ok, working on my 1929 Brake Set-Up - Adjustment I have installed all NEW Brake springs, repacked all bearings and followed the Instructions for adjusting & setting up the brakes per the repair manual/ service news. In doing so it seems like the brakes are 90% rear & 10% front, as I have to press the pedal almost to the floor BEFORE the front brakes even kick in. I have the car on jack stands so I can set/ adjust/ test the brakes. I used the brake tool to set the proportioner and linkages. There seems to be play in the proportioner, wonder if there is anything missing, or should it be loose ? I also have the floor board out so I can watch the linkages and proportioner. As soon as I press the pedal the proportioner moves but ONLY the rear cross shaft turns activating the rear brakes. then at about 90% to the floor the FRONT cross shaft begins to turn activating the front brakes. I did test the freedom and ability to TURN BOTH cross shafts freely and easily by hand BEFORE connecting ANY rods or LINKAGES. I also checked all linkages and MOVING parts to ensure they moved freely and easily with very little effort. Can anyone provide some insight as to what I am doing wrong or is this HOW the brakes should work on the 1929. I was under the understanding it should be 60% rear & 40% front but figured that when you start pressing the pedal BOTH cross shafts would begin to turn and activate front & rear brakes. Or do the FRONT only kick in ONCE the rear are activated and provide resistance for the front shaft to turn ?? Trying to get them set properly...
Posts: 19,756 Likes: 62
Posts: 19,756 Likes: 62 |
Front brakes were still considered hazardous so they are adjusted so the rear brakes need to be activated before the front. You probably need to adjust the rear tighter, take slack out of the rods/pivots/linkage/pins. Once the front brake linings contact the drums much of the stopping is by them.
Thanks Chipper... I know one posting we talked about having to adjust the brakes once they settle in. On my rear the shoes are not the same shape as the outer drums. then END points contact before the middles does, I figure that after some driving and testing they will settle in and seat properly. In setting the rear brakes, the ends are set to the right distance, but that leaves the middle further out. is there anything that I can do or should do ?? Rear Shoes - Side View May be hard to see In emailing with Chip (NC Chip) he asked me to post some pictures of the setup to make sure I have the proportioner correct as well as the linkage between the pedal & proportioner. Prop Side ViewProp Top ViewCross Shaft EndsIf you look at the Prop Top View & Side View, should there be space between the linkage (the U-Shape part that is pinned on each side), and the part it mates with. at least 1/8" or more space in there... Seems to be a lot of slop, should there be ??
I think that you need to set the rear linings a bit tighter or reshape the bands so they better fit the drums and then tighten so the middle has the hacksaw blade gap. As long as the linings don't drag somewhere else it should be okay. You should have 1/2 pedal or more when brakes begin to grab.
ok... what would be the best way to reshape the bands ?? I do not want to damage the shoes or bands by any means. if I adjust the middle to have the hacksaw blade gap the ends of each band drag... You should have 1/2 pedal or more when brakes begin to grab. based on that I need to do some adjusting/ tinkering...
First try bending by hand aided by a piece or two of wood. The closer to a perfect circle the better.
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
The assembly of the proportioner looks correct in your photos, but the arms on the cross shafts that connect to the link attached to the brake pedal are not nearly as close to vertical as mine are on both of the '29s. You may want to try unhooking the brake pedal linkage and adjusting the clevises on the actuating rods leading to the wheels, both front and rear so that the arms on the cross shafts to which the brake pedal attaches are nearly vertical when the brakes are fully engaged.
I'll post a photo of mine.
All the Best, Chip
"It's wise to choose a SIX"
Posts: 78 |
I'm about 10 yrs late joining this thread, but it looks like the place to ask my questions regarding the rear service brakes (exterior bands) on my '29 LQ 1.5 t truck. Last summer, I was never completely satisfied with my rear service brake set-up (pedal play, band-to-drum gaps, etc), but the stopping performance was acceptable, so I thought I'd put some road miles on the bands and re-visit the set-up this spring. So that's what I'm doing! To make a long story short(er), I believe my rear bands could stand some 'rounding'. With excessive gaps at the heels and toes, (and therefore excessive pedal play) there are areas where the bands still excessively drag on the drums. After doing additional research, I came across the attachment showing a 'rounding hand tool', but it gives no part number to aid in finding one. Has anyone ever come across a 'hand-type rounding tool' as shown in Fig. A 10 of the attachment? used one or an acceptable substitute? know if its use will damage new, woven linings? Thanks again for your help and advice. https://www.dropbox.com/scl/fi/b7pf...rlkey=heauq45gsfekwuj9klqp8ur1c&dl=0
Topics59,071
Posts429,066
Members18,308
