If you are a VCCA Member, then you can now use the main navigation bar on the club's
HOMEPAGE to go directly INTO the
Members Only area.
The "requirement" is that you need to login to the
Members Area first,
in a separate browser window.
After that, all of the "members" links on the HOMEPAGE will take you directly to the appropriate page.
FIRST SCREEN VIEWIn this IE view, the first tab (VCCA) is the
VCCA Homepage.
The second tab (Welcome) is the
MEMBERS page. (
http://vcca.org/members)
SECOND SCREEN VIEWOnce you've logged in to the
MEMBERS page, then go back to the
VCCA HOMEPAGE and select the
Member Services pulldown.
THIRD SCREEN VIEWEach of the listed selections has a
fly-out list of additional items that you can select from.
If you've successfully logged in to the
Members area, and kept that window open, then all of the links will take you directly inside to the
Members area.
