Posts: 4 |
hi everyone quick question when driving my 48 fleetmaster 1st gear no problem when in 2nd gear going good and i let off the gas my shifter jumps going into 3rd doing ok then pops out checked ALL mounts and they seem good any idea what can cause this and how can i fix it it is an open drive by the way i bought it like this,, thank you in advance
Posts: 1,194 |
What engine and transmission are in your car?
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
Is the vacuum assist shift hooked up or does it have a conversion kit?
Posts: 4 |
235 i believe a 54 and the tranny just a 3 speed colum no vacume
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
If it is an open driveshaft, it isn't a 54 transmission. Need to get the casting numbers off of the trans. Also get the stamped numbers off of the block behind the distributor to pin point what engine you have. With the transmission changed out it could be a linkage or lever problem.
Posts: 4 |
ok heres what i found out casting on the engine has con3 H224 the tranny i believe is a truck tranny huge bell housing long shaft rearend is out of an 76 regal also i did take a good look at the motor mount the rubber look thrashed bunch of little cracks but dont jump the gun yet and say that it,,, because wouldnt it jump around in all gears???? one more thing the engine my buddy says it might be from a 1964 because of the water pump but they did not make 235 in 64 i say its a 54
Posts: 3,136 |
What engine and transmission are in your car? Thinking back on an old post on this subject, and although it was directed at 216's with stock transmissions "popping" out of 3rd...Wasn't one solution was to add a "shim" between the bottom of the transmission and the bell housing...?
Posts: 4 |
ok heres an update on my tranny,,, i know its been awhile was working on other things,, ok changed out the tranny mount checked every nut and bolt, motor mounts, everyrthing looks great,,, solid!!! did it change anything??? not a damm thing i went on a cruise to see how it was going to do and yeah nothing changed,, i just dont know where to go from here a friend says it has to be the tranny something about some dogs inside might be worn might have to rebuild it i did forget to get the numbers off the tranny,, the motor is H224 july 22nd 1954
Posts: 885 |
Just a humble opinion here, but if it is linkage adjustment problem and you don't have the vacuum shift, I posted my idea in the 46-48 forum on 9-12-13 post #289114. Perhaps it may help??? If not, perhaps your phone # via PM and I can call you to see if I can help. Sometimes a talk on phone is better than a post.
Best to ya.
Jim.
Posts: 619 |
I have a similar problem when cruising long distances over a 100 miles or so on the highway. Everything going along smoothly the suddenly she will pop out of gear. Never does it while driving in the city just on the highway and only after driving for about an hour or more. MY FIX WAS A BUNGY CORD from the shifter to the bottom of the seat. cheapest accessory I ever purchased. I call it my anti-slip device!!
Posts: 3,578 |
i just did a full adjustment to my vacumm assist and shifting linkage etc.I followed the shop manual to a T but the 48 still falls to neutral when coasting ?
0 members (),
73
guests, and
20
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
