Peterw Offline OP
Hi
I have a 1930 Sports Roadster. The dash is just a solid slab of wood, with the correct instruments & knobs, but I think I have seen much fancier central panels on the dash, which contain the instruments etc.
Any comments, or is this the way it should be?
Peterw
PeterW
Become a Member!
The instrument panel should be made of metal.
By the way, for better coverage with your questions you might want to post in the 1929-32 forum like you did with your other questions.
