Posts: 1,558 |
I took my '48 in for a NYS inspection this morning and on the way, I noticed my speedometer needle has fallen off (it did pass inspeection). Is there any way to get the bezel and glass off the speedometer from the front or does the speedometer have to be removed from the dash. If that needs to be done, I assume it is done from the rear of the dashboard. Any hints? Thanks. Beamer
You will have to "yard" it out so you have access to it. Once out of the dash some careful metal bending and you can take the speedo apart and clean everything up and then replace the needle. (This is assuming the end of the needle shaft was not broken off with the needle.)
Posts: 1,740 Likes: 11
Posts: 1,740 Likes: 11 |
You will have to "yard" it out That's code for, stand on you head, remove four nuts from the studs and slide out the back of the dash. Be sure to let someone know where they might find you if you go missing!
Posts: 3,578 |
Inspection?sorry to hear that Beamer,in Wash State no inspections required for vintage cars...The speedo and clock should be a very tight fit and after removal and possibly even re-installation some touch up paint may be required
Posts: 3,136 |
Is there any way to get the bezel and glass off the speedometer from the front or does the speedometer have to be removed from the dash. If that needs to be done, I assume it is done from the rear of the dashboard. Any hints? Thanks. Beamer Unless you want to use a hammer...I suggest going behind the dash... it's easy, don't sweat it...Needles are available from FS...A hammer is funner... Don't forget to wear safety glasses...
Posts: 1,558 |
Not only does NY require inspections but if you have the vehicle registered with historical plates, which I do, you have to reregister it every year instead of every two years like regular vehicles. I guess they think us old car nuts have deep pockets! But, like everything else, we are taxed to death and if we are not taxed outright, there are all kinds of taxes disguised as fees. Whoa! Wrong thread!!! Beamer
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
This may be a repeat. And disconnect the battery whilst you're a-yarding. Charlie
Posts: 3,578 |
Beamer did you get the speedo and inspect it yet?
Posts: 29,848 |
Posts: 860 |
JYD-Same here in Missouri. One time registration no safety or emission inspections.
hoppy
"Four-Doors-Forever"
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Best way to get at the underside of the dash, is to pull the front seat and lay down some old blankets. This lets you get under the dash alot easier. I did this when I rewired my 48 last year.
Posts: 1,558 |
It was in the 90's here yesterday and will be the same today. Too hot for this old man to be crawling up under a dash! re registrations; I guess some states are more progressive, or at least not as regressive, as NY. Our very wealthy lawmakers have to keep money coming in from somewhere to maintain their lifestyles! Beamer
1 members (swedechev),
78
guests, and
15
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
