Hi there,
I have recently finished installing new glass etc to my 34 chev std 4 door sedan. I had to start from scratch, nothing was there as a guide.
I installed the interior felt wipes, to the actual door internal steel trim frame, by using pop rivets.
They are impossible to see from the outside, looking through the glass.
The outside wipes were glued on using 5 min Araldite, using a length of wood wrapped in glad-wrap ( to prevent it sticking to the wood) and held by 3 small G-clamps, until it set.
I had to first make up and fix small timer fillets to the door frame, exactly shaped to fit the form of the door, it had a small curve and had to make it parallel with the glass, when this was done, I then stapled and glued the rubber moulding to the timber fillets.
It was a fiddly job, one piece at a time, but in a week all were installed and every thing works well.
Peter
