#233043 02/02/12 10:08 PM
6wheel Offline OP
Anybody know the name (and paint code) of the color on the steering column of my '41 special deluxe coupe? It is a tan color, and I assume it is a factory color. Whoever restored my car painted the column inside the car, but failed to paint it under the hoood. Any help would be appreciated.
Sid
6wheel Offline OP
Since posting this topic I remembered the paint chips at Auto Color Library. The color chip that most closely matches is Santone Poly. Does anyone know if this was a color used on steering columns and interiors in 1941? I've owned two 1941 Chevrolets, and both had a cream or tan color for the interior trim. Was that true for all 41's, or were some interiors painted other colors?
Thanks,
Sid
All Special Deluxe models had the rose/biege color. I believe that paint is available from either Chevs of the '40's or the Filling Station.
The Master Deluxe had a tan color or could be called a very light brown.....like milk choclate
6wheel Offline OP
Thanks Chev Nut, that's easy enough. I found the paint in Chevs of the 40's catalogue and will order it.
Sid
