Posts: 168 |
does anyone know if the cabin dimensions remained the same for 37 and 39. specifically, i'm planning to put a 39 split bench seat in a 37. will it fit?
The front seat will exchange OK. The back seat of a 1937 is not as wide as a 1938-39 back seat. The rear wheel tread was wider in 1938 so the wheel wells were pushed out farther making more room for the wider rear seat.
Posts: 168 |
thank you very much Chev Nut for the reply
