Posts: 81 |
I need to remove the drivers side wiper transmisson on my 1940 tudor. A couple fo questions. [1] Does the defroster duck have to be removed to access it? [2] Does the link get disconnected from the wiper motor or from the transmission? Seems to be very difficult to get to any of these parts. HELP
Posts: 7,032 Likes: 107
Posts: 7,032 Likes: 107 |
I can't speak for a '40 but my '38 should be similar. On mine the linkage arm disconnects from the transmission. There's a spring clip that you remove that releases the arm. I don't need to remove the defroster duct to access the transmission fastener. I found it much easier to remove the seat when working under the dash. Spring clip.
Posts: 4,446 |
Amen on that. Removing the seat makes a huge difference unless you're 20 years old.
Posts: 81 |
Tiny thanks for the reply. There seems to be a ball joint swivel at the transmission but I don't see anyway to unhook it. May be they have to unhookmat the wiper motor?
1 members (swedechev),
50
guests, and
31
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,069
Posts429,046
Members18,307
