Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
removeing rear half of the 31 sedan #232971
02/02/12 04:32 PM
02/02/12 04:32 PM
nc
O
oboy Offline OP
oboy  Offline OP
O
nc
Well i'm getting started on the wood removed the front cowl all the doors and metal trim.Trying to get the back half off now and the trim molding on top is in good shape.but getting it out without bending to pieces should i try to save it or can i get new when going back.looks like you should peel up one side to get access to nails.and speaking of nails MAN lot's of nails.
Wake up to learn something new everyday.
The Filling Station 1929-32
Re: removeing rear half of the 31 sedan [Re: oboy] #232975
02/02/12 04:49 PM
02/02/12 04:49 PM
Hawthorne, New York
karl31 Offline
karl31  Offline
Hawthorne, New York
If you try to separate the molding it's doubtful that you can ever get it back in shape. I would suggest that you try to lift the molding and cut off the nail ends. Then when you instal it again yo can use fewer nails (drill small holes which can be filled).
However there is replacement molding that will work well.
I was fortunate enough to find great quality reproduction molding (no longer available) after I screwed up an attempt to remove the original. Still haven't figured out how they managed to bend the original molding at the rear of the top.
karl
Re: removeing rear half of the 31 sedan [Re: karl31] #233009
02/02/12 09:59 PM
02/02/12 09:59 PM
Dayton/Beavercreek, Ohio
B
Back Roads Offline
Back Roads  Offline
B
It is possible to reuse the original if you are very careful. I did it on our 31 Coupe and it came out fine.
56 year member
Joined June 1961
Re: removeing rear half of the 31 sedan [Re: oboy] #233020
02/02/12 11:41 PM
02/02/12 11:41 PM
Wisconsin, USA
Chevy1778 Offline
Chevy1778  Offline
Wisconsin, USA
I built a wooden jig cut to the arc of the roof for both front and rear of the car. The jig allowed me to bend the roof channel very precicely for and exact fit.
Re: removeing rear half of the 31 sedan [Re: Chevy1778] #233102
02/03/12 01:50 PM
02/03/12 01:50 PM
nc
O
oboy Offline OP
oboy  Offline OP
O
nc
It's comeing off so far takeing slow have one half and rear off the car.The guy that missed and went straight thru the metal is the guy thats makeing it hard.thanks for the tips i'm just going to take my time.Going up to va to get some wood from Bill Cartwright.He has most of what i need and the rest is 12 months away so i have time.Chevy1778 did you trow the jig away?
Re: removeing rear half of the 31 sedan [Re: oboy] #233123
02/03/12 04:46 PM
02/03/12 04:46 PM
Wisconsin, USA
Chevy1778 Offline
Chevy1778  Offline
Wisconsin, USA
Yes, the jig is gone.
Re: removeing rear half of the 31 sedan [Re: Chevy1778] #233484
02/06/12 11:09 PM
02/06/12 11:09 PM
nc
O
oboy Offline OP
oboy  Offline OP
O
nc
well got it all off in good shape.I would think this is stainless feels like aluminum.
Re: removeing rear half of the 31 sedan [Re: oboy] #233495
02/07/12 12:22 AM
02/07/12 12:22 AM
Nova Scotia, Canada
Gunsmoke Offline
Gunsmoke  Offline
Nova Scotia, Canada
They are aluminum, which is partly why they cannot be unfolded without breaking the hinge joint. As well, most likely have sealant in joint making it even harder to get them apart. Other topics here suggested cleaning them up, removing/snipping off old nails, drilling holes for countersinking new screws, and then filling screw heads/painting. Haven't tried that procedure, but understand it works!
Re: removeing rear half of the 31 sedan [Re: Gunsmoke] #233500
02/07/12 12:41 AM
02/07/12 12:41 AM
nc
O
oboy Offline OP
oboy  Offline OP
O
nc
thought it was, some nails look like i can reuse if i'm carefull the rest i think that trick will work.
Moderated by  32confederate, d2d2
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
0 registered members (), 3 guests, and 5 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
aland, Stickdude, Achipmunk, centercut, Ilike461019
15122 Registered Users
Forum Statistics
Forums69
Topics49,974
Posts362,381
Members15,122
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
