Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
engine colors #232872
02/01/12 05:36 PM
02/01/12 05:36 PM
bath co. virginia
J
Jerry27 Offline OP
Jerry27  Offline OP
J
bath co. virginia
i am restoring a 27 to be correct as possible. i have the green paint from the filling station. was everything green except the valve cover and intake manifold? was the pushrods painted as there are no covers over the 27.i need all the details i can get. i also thought there was a grey in 1927. thanks in advance
The Filling Station 1912-28
Re: engine colors [Re: Jerry27] #232875
02/01/12 06:43 PM
02/01/12 06:43 PM
Issaquah, WA
Bill Barker Offline
Previous ChatMaster
Bill Barker  Offline
Previous ChatMaster
ChatMaster - 5,000
Issaquah, WA
If somebody wants to update this chart for 1927,
I'd be happy to post it in Members Resource Center.
http://1931chevrolet.com/colorparts.htm
Bill Barker
(VCCA Member: 9802)
Re: engine colors [Re: Jerry27] #232954
02/02/12 02:26 PM
02/02/12 02:26 PM
bath co. virginia
J
Jerry27 Offline OP
Jerry27  Offline OP
J
bath co. virginia
there seems to be some interest in my question. 66 views. why can i not get an answer? there seems to be lots of interest in the 28 but hardly any for the 27. i do realize that we only have rear wheel brakes and are down on horsepower but we are liked just the same. what gives?
Re: engine colors [Re: Jerry27] #232972
02/02/12 04:41 PM
02/02/12 04:41 PM
The Villages, Florida
O
Oldie Offline
Oldie  Offline
O
What gives here is that there are a lot of opinions on the engine paint subject within this chat site. At the risk of being made to walk the plank, I'll attempt to answer your questions.
The '27 engine block, cylinder head, cylinder head water outlet housing, Air cleaner inlet can (affixed to the exhaust pipe), and oil pan were painted a gray/green color much like the old Bell telephone bell logo. The Filling station 4 cylinder paint is as close as you'll get. I believe the water pump was engine color but not sure about it.
The '27 engine push rods were unpainted.
The Starter motor. generator, generator mounting bracket and adjusting bracket were black. The engine oil fill tube and fill cap were black. The fan blade(S) were black. Throttle and distributor linkages were black. The valve cover and spark plug wire standoff bracket were black. The oil filter and coil bracket attached to it were black. The inlet manifold was black. The air cleaner support bracket between the valve cover rear bolt and the air cleaner was black. Carburetor body questionable, either black or unpainted. Carburetor choke wire to inlet manifold support bracket was black. Exhaust manifold unpainted but because they rust so quickly most of us paint then a cast iron color with a high temp paint (your option).
Re: engine colors [Re: Oldie] #232988
02/02/12 07:00 PM
02/02/12 07:00 PM
bath co. virginia
J
Jerry27 Offline OP
Jerry27  Offline OP
J
bath co. virginia
thanks oldie, the info that you posted is what i wanted. i just wish i could get a better response from the 27 guys. seems we are a rare bunch. what-cha think? thanks again jerry
Re: engine colors [Re: Jerry27] #233002
02/02/12 08:53 PM
02/02/12 08:53 PM
Sydney, Australia
C
chevguroo Offline
chevguroo  Offline
C
Sydney, Australia
Not sure about 1927, but I had a low mileage 28 coach never restored (bar guards repainted) and still had all original engine paint. The car was imported by me from St.Paul Minneapolis about 20 years ago. The engine colour was grey/green sorta like an dull olive. The rocker/valve cover and side plates were green as was the air cleaner, the bolt on bits as stated in the earlier post were black.
If you think about it (in 28 at least) an engine going down the production line ready to be painted would have everything painted the same colour as too cost prohibative to have different colours.
I've still got that rocker cover as reference/proof to them being green and have had the colour reproduced.
BTW I found under the back seat were the Willard battery warranty brochure, a tag telling the salesman how to start the car, another tag stating what tyre pressures to use. Plus on the rear floor were a set of 21" snow chains and a few of the original tools.
Chris
Re: engine colors [Re: Jerry27] #233042
02/03/12 02:04 AM
02/03/12 02:04 AM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
Part of the problem is the '27 Technical Adviser does not frequent ChatII. He shows up occasionally. He has a bunch more experience that the rest of us.
Re: engine colors [Re: chevguroo] #233046
02/03/12 02:14 AM
02/03/12 02:14 AM
bath co. virginia
J
Jerry27 Offline OP
Jerry27  Offline OP
J
bath co. virginia
thanks for sharing your 28 story. what ever happened to the 21 in. chains?
Re: engine colors [Re: Chipper] #233049
02/03/12 02:18 AM
02/03/12 02:18 AM
bath co. virginia
J
Jerry27 Offline OP
Jerry27  Offline OP
J
bath co. virginia
ray, i didn't know there was anybody better than you. PS. carb is still working great.
Re: engine colors [Re: Jerry27] #233061
02/03/12 03:10 AM
02/03/12 03:10 AM
Edmonton, Alberta
A
Arend Offline
Arend  Offline
A
Edmonton, Alberta
So if I'm hearing this correctly, the '27 engines were basically painted the same colors as the '28 engines. Right?
Re: engine colors [Re: Arend] #233069
02/03/12 04:18 AM
02/03/12 04:18 AM
Sydney, Australia
C
chevguroo Offline
chevguroo  Offline
C
Sydney, Australia
I've stiil got the chains, and actually picked up another set, down here in Aus.
Chris
Re: engine colors [Re: chevguroo] #233081
02/03/12 05:45 AM
02/03/12 05:45 AM
Issaquah, WA
Bill Barker Offline
Previous ChatMaster
Bill Barker  Offline
Previous ChatMaster
ChatMaster - 5,000
Issaquah, WA
...and.... I'm wondering whether I should turn OFF the VIEWs feature. It really is misleading. It includes ALL HITS to the posting, including spiders, crawlers and other non-value added visitors (eg. non-humans). I can see where people get mislead thinking that they're being overlooked.....
Thoughts?
Bill Barker
(VCCA Member: 9802)
Re: engine colors [Re: Bill Barker] #233110
02/03/12 03:11 PM
02/03/12 03:11 PM
Chipper Offline
Chipper  Offline
Bill,
I would suggest keeping it for now and adding a comment somewhere indicating that all views are not human but Google and other computer programs. That is how Google finds the sites that are listed when a Google search is performed.
As a comment: it is becoming increasingly common for a Google search for info on an old Chevrolet to have one of the top ten "hits" to be a ChatII post.
Moderated by  AntiqueMechanic
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
4 registered members (Rustoholic, pushrod, XLVIIdriver, ken48), 7 guests, and 5 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,518
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
