Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
'37 chev. coupe rear diff. #232837
02/01/12 04:08 AM
02/01/12 04:08 AM
Billerica, MA. USA
D
dfd37chev Offline OP
D
Billerica, MA. USA
I'm in contact with another member about purchasing a'37 master coupe rear diff. for my '37 Master DeLuxe. I'm trying to minimize the amount of work the owner will need to perform before I arrive. My question: Can the propeller shaft and pinion be separated from the rear differential without removing the axles?? I did talk to Chevgene and he did say they have to be. Thought I would put it out there for discussion. Thank you everyone and to Chevgene for accepting my P.M.
VCCA # 047832
Re: '37 chev. coupe rear diff. [Re: dfd37chev] #232849
02/01/12 11:10 AM
02/01/12 11:10 AM
NC usa
4
41specialdeluxe Offline
NC usa
Dave,
Gene is right, as usual. iagree
You have to put the car on stands, split the universal, take off the rear cover and catch the oil, take out the front bolts at the differential, remove the spacer, remove the keys holding the axles in, slide the axles out enough to clear, and pull the torque tube with the ring gear and pinion out the front. Not hard to do. dance
Re: '37 chev. coupe rear diff. [Re: 41specialdeluxe] #232852
02/01/12 01:30 PM
02/01/12 01:30 PM
Central Kentucky
kwchevy1940 Offline
kwchevy1940  Offline
Central Kentucky
iagree It's not a difficult job but like Charlie said.. have a pan to catch the oil as it could be a messy job and make you say "turrible" words when that oil comes out if you aren't ready. dance
Ken's 1940 Special Deluxe Sedan
1970 Cadillac Hearse
Re: '37 chev. coupe rear diff. [Re: kwchevy1940] #232871
02/01/12 05:35 PM
02/01/12 05:35 PM
Billerica, MA. USA
D
D
Billerica, MA. USA
I would like to apologize to all... I was looking over the cut-away view in my manual with a co-work when he noticed that the main caps that hold the carrier to the center section are not visable. Ssssoooo I had over looked a key component of the assembly and so of course the axles have to be removed to extract the center section. Can anyone say duh!! As you all have probably guessed I've either had a malfunction of the gray matter or I have no clue. I'll leave that for you all to decide. Again, thank you all. (and a bigger apology to Chevgene)
VCCA # 047832
Re: '37 chev. coupe rear diff. [Re: dfd37chev] #232878
02/01/12 06:59 PM
02/01/12 06:59 PM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
Do no touch the main caps.when removed from the car you will have the torque tube and te center section of the rear end. will pull forward out of the axle banjo housing. The ring gear and pinin will not be disturbed.
Chevgene
Moderated by  37Blue
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
3 registered members (AntiqueMechanic, lachlan31, Junior_Stock), 4 guests, and 5 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
aland, Stickdude, Achipmunk, centercut, Ilike461019
15122 Registered Users
Forum Statistics
Forums69
Topics49,974
Posts362,381
Members15,122
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
