#232295 01/27/12 12:19 AM
rjp Online Content OP
OP Online Content
I am working on a 31 roadster, The two toe board brackets on the side that go from the cowling down to the sill plate, Is it the same as a inclosed cab model? chevrolet v.s. fisher. The parts book for the roadster does have no. for the right and left, but the closed cab the cowl and brackets are together. Roger I can see where mine were spot welded at the top, but thats all I can tell. Thanks
OP Online Content
The left one is the bracket that has the dimmer switch mounted
You might check with Bow-Tie Reproductions. http://www.bowtiereproductions.com/
Seem to remember that they had them available as repops in the past.
OP Online Content
bumer, I called Bow Tie and they said no, any one with suggestions? Roger
Both were badly rusted on bottom edge next to floor on my '31 coach, and I assume were similar to what you need. I managed to find a used one on eBay (they do not show up very often), and fabricated a repair to the other one to get a good pair. Mine are now bolted in place (both of them had holes for 2- 1/4" bolts into lower edge of cowl). I considered welding them in place but bolting with lock nuts seemed simpler. They take 3 wood screws into the floor. Originals also had 2 nuts affixed to receive toe board plywood machine screws. All 4 of those holes in mine were stripped or missing, have not yet decided whether to re-tap, or try another approach
If you find that the brackets are the same that a 32 sedan uses I have a couple of spares.
OP Online Content
Don Rossi had a pair ,he is sure that they came out of that car! That would be good. Idid get the car from him. He has been laid up for a while due to back sergery. Thanks Ill be able to tell more when he is up and around. Roger
