Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
31 toe piece brackets #232295
01/27/12 04:19 AM
01/27/12 04:19 AM
wa
R
rjp Offline OP
rjp  Offline OP
R
wa
I am working on a 31 roadster, The two toe board brackets on the side that go from the cowling down to the sill plate, Is it the same as a inclosed cab model? chevrolet v.s. fisher. The parts book for the roadster does have no. for the right and left, but the closed cab the cowl and brackets are together. Roger I can see where mine were spot welded at the top, but thats all I can tell. Thanks
The Filling Station 1929-32
Re: 31 toe piece brackets [Re: rjp] #232298
01/27/12 04:28 AM
01/27/12 04:28 AM
wa
R
rjp Offline OP
rjp  Offline OP
R
wa
The left one is the bracket that has the dimmer switch mounted
Re: 31 toe piece brackets [Re: rjp] #232301
01/27/12 04:43 AM
01/27/12 04:43 AM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
You might check with Bow-Tie Reproductions. http://www.bowtiereproductions.com/
Seem to remember that they had them available as repops in the past.
Re: 31 toe piece brackets [Re: Chipper] #232411
01/28/12 03:49 AM
01/28/12 03:49 AM
wa
R
rjp Offline OP
rjp  Offline OP
R
wa
bumer, I called Bow Tie and they said no, any one with suggestions? Roger
Re: 31 toe piece brackets [Re: rjp] #232700
01/30/12 09:12 PM
01/30/12 09:12 PM
Nova Scotia, Canada
Gunsmoke Offline
Gunsmoke  Offline
Nova Scotia, Canada
Both were badly rusted on bottom edge next to floor on my '31 coach, and I assume were similar to what you need. I managed to find a used one on eBay (they do not show up very often), and fabricated a repair to the other one to get a good pair. Mine are now bolted in place (both of them had holes for 2- 1/4" bolts into lower edge of cowl). I considered welding them in place but bolting with lock nuts seemed simpler. They take 3 wood screws into the floor. Originals also had 2 nuts affixed to receive toe board plywood machine screws. All 4 of those holes in mine were stripped or missing, have not yet decided whether to re-tap, or try another approach
Re: 31 toe piece brackets [Re: rjp] #232778
01/31/12 05:27 PM
01/31/12 05:27 PM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
If you find that the brackets are the same that a 32 sedan uses I have a couple of spares.
Re: 31 toe piece brackets [Re: m006840] #232792
01/31/12 08:19 PM
01/31/12 08:19 PM
wa
R
rjp Offline OP
rjp  Offline OP
R
wa
Don Rossi had a pair ,he is sure that they came out of that car! That would be good. Idid get the car from him. He has been laid up for a while due to back sergery. Thanks Ill be able to tell more when he is up and around. Roger
Moderated by  32confederate, d2d2
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
0 registered members (), 2 guests, and 3 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
Stickdude, Achipmunk, centercut, Ilike461019, DanPryor
15121 Registered Users
Forum Statistics
Forums69
Topics49,964
Posts362,269
Members15,121
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
