#232227 01/26/12 03:58 PM
blue38 Offline OP
Have a friend who says he will use asbestos fiber and grease in the cup to stop any potential leak...this can't be right . What is the correct grease?
Water pump grease is avabill from equipment suppliers that sell thrash pumps or Kendall has it.
Al
It's also available directly from "Lubriplate", one of the manufacturers.
All the Best, Chip
"It's wise to choose a SIX"
rjp Offline
Or the filling Station
Perhaps your friend is referring to the grease cup "seal",which is a small groove in the body of the grease cup,in which a there was possibly a small string of asbestos to stop the water pump grease from leaking past.A possible alternative may be a piece of plumbers hemp sting greased and rolled tight enough to fit in the groove on the grease cup body to make a seal as the cup is screwed down to prevent grease leakage.
chevy
CJP'S 29
Lubriplate #115 is a special grease for water pumps. Also the cup seal can be improvised by using a thin oring and some super glue.
