#232200 01/26/12 11:09 AM
Pop Offline OP
Where can I buy an extra loud flasher? I have exhausted the internet, all dead ends. NAPA claims to have one, but it doesn't work or only has 2 prongs.
This must be available for the hearing impaired or noisy vehicles.
Become a Member!
Pop #232217 01/26/12 12:32 PM
I don't know of an extra loud flasher but you could install a couple of small bright lights that you could see instead. It could be installed with clamp and plug in connections if it needed to be removed for judging.
Pop #232234 01/26/12 05:08 PM
Go to radio shack and buy a small buzzer, wire it in the flasher feed to switch circuit, they are available in 6 or 12 volt and can be easily hidden.
Al
a3alf #232890 02/01/12 06:23 PM
Pop Offline OP
Thanks for the tip on the radio shack buzzer. It worked perfectly and installed very easily.
Chipper #232899 02/01/12 08:05 PM
Chipper,
I also tried the Radio Shack route, but the buzzer wasn't loud enough to make a difference.
So, I installed one of these in my '36FB to help me remember to cancel the signal after turning. I works great, and believe me you can't forget to turn it off! Turn Alarm
Wally
1936 Low Cab Pickup
