Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Oil preassure gauge pipe location? #232182
01/26/12 09:08 AM
01/26/12 09:08 AM
Australia.
B
blueyAU Offline OP
blueyAU  Offline OP
B
Australia.
Hi there,
I am fitting up the oil pressure gauge to my 34 chev std.
The original probably had copper line from the lower engine block to the gauge?
The only fitting that I could buy were brass for the attachments and very thin plastic pipe for the transfer of oil to the gauge.
Does anyone have a pic of the location of the pipe and its route to the gauge?
To protect the fragile plastic pipe I had an " IDEA ", to thread it through some small gauge copper pipe, and bend and fix it along the way to the various parts of the superstructure as needed.
This is necessary, because the plastic pipe is very "coiled" and will not stretch to a straight line or anything else?
Peter
2 yy's u r
2 yy'u b
I C U R
2 yy's 4 me
The Filling Station 1933-36
Re: Oil preassure gauge pipe location? [Re: blueyAU] #232211
01/26/12 04:14 PM
01/26/12 04:14 PM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
Will the plastic pipe hold "hot" oil? I personally would not trust it and instead use copper tubing. We can still get the copper tubing in the USA but have to order it from hardware companies as it is not commonly stocked. Maybe you can also do that in OZ.
Re: Oil preassure gauge pipe location? [Re: Chipper] #232238
01/26/12 09:19 PM
01/26/12 09:19 PM
New York
A
a3alf Offline
a3alf  Offline
A
New York
Plastic pipe supplied with oil pressure gauges will with stand heat. To uncoil this pipe use a heat gun carefully, when going through a hole in metal use a rubber gromet and side fold clips will hold it on flat surfaces. I have used it on meany projects.
Al
Re: Oil preassure gauge pipe location? [Re: a3alf] #232261
01/27/12 12:11 AM
01/27/12 12:11 AM
Australia.
B
blueyAU Offline OP
blueyAU  Offline OP
B
Australia.
Hi there all,
thank you for your reply's.
I used the same oil gauge kit on my International A414 tractor last year and it is special tubing to withstand heat. It has worked well on the tractor.
I'm still unsure of it path to the oil pressure gauge, could anyone have a look and give some idea of where it can safely be run and fixed?
Peter
2 yy's u r
2 yy'u b
I C U R
2 yy's 4 me
Re: Oil preassure gauge pipe location? [Re: blueyAU] #232275
01/27/12 01:26 AM
01/27/12 01:26 AM
Chipper Offline
Chipper  Offline
I don't have a '34 so can't take photos of the exact routing. The tubing runs from the distributor to a bracket on the ledge above the oil pan then makes a gradual 90 deg. bend up the fire wall to another 90 deg. bend and through the rubber insert in the slot in the firewall. Finally direct to the back of the oil gauge.
Re: Oil preassure gauge pipe location? [Re: blueyAU] #232315
01/27/12 09:13 AM
01/27/12 09:13 AM
Goulburn Australia
tonyw Offline
tonyw  Offline
Goulburn Australia
Peter
If you have 1 of the after market type guage kits the nylon tubing supplied hasnt given any trouble with the 5 or 6 that I have fitted (I generally use VDO).
I havent looked for steel or copper tubing of that size (1/8") so I am not very helpful at this stage.
Re: Oil preassure gauge pipe location? [Re: Chipper] #232385
01/27/12 11:59 PM
01/27/12 11:59 PM
Australia.
B
blueyAU Offline OP
blueyAU  Offline OP
B
Australia.
Hi there Tony and Chipper,
thank your for your reply s.
Chipper:I now have a general idea of how and where to run the pipe idea
Tony: I am going into the local brake place to see what they have in the way of copper pipe..
Cheers
Peter
2 yy's u r
2 yy'u b
I C U R
2 yy's 4 me
Re: Oil preassure gauge pipe location? [Re: blueyAU] #232494
01/29/12 12:20 AM
01/29/12 12:20 AM
Goulburn Australia
tonyw Offline
tonyw  Offline
Goulburn Australia
Peter
I doubt they will have anything that small as 3/16" is the general brake pipe size since about 1960. Considering the price of copper these days and the limited use of the smaller would not be a stock line for most business but is worth asking just the same.
Re: Oil preassure gauge pipe location? [Re: tonyw] #232713
01/30/12 11:14 PM
01/30/12 11:14 PM
Australia.
B
blueyAU Offline OP
blueyAU  Offline OP
B
Australia.
Hi there Tony,
yesterday I found an oil pressure gauge kit in copper from a local auto accessory shop for $20-, so I bought it.
Now all I have to find are very small clips to secure the tiny pipe....
Peter
2 yy's u r
2 yy'u b
I C U R
2 yy's 4 me
Re: Oil preassure gauge pipe location? [Re: blueyAU] #232746
01/31/12 10:49 AM
01/31/12 10:49 AM
Goulburn Australia
tonyw Offline
tonyw  Offline
Goulburn Australia
You have done well, the clips arent hard (fiddly) to make yourself
Re: Oil preassure gauge pipe location? [Re: tonyw] #233994
02/11/12 08:47 PM
02/11/12 08:47 PM
Citrus Heights Ca
fdwrench Offline
fdwrench  Offline
Citrus Heights Ca
I found the fittings and the copper tubing at my local Napa store. The part number for the fittings is WH6100x2. It is a Weather Head fitting.
I would think that it would be available in Australia
Ed
32 1/2 ton panel delivery
55 Cameo
And a Plymouth
Re: Oil preassure gauge pipe location? [Re: fdwrench] #234018
02/12/12 01:29 AM
02/12/12 01:29 AM
Citrus Heights Ca
fdwrench Offline
fdwrench  Offline
Citrus Heights Ca
Then I ran across this on ebay:
http://www.ebay.com/itm/370584414243?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
55 Cameo
And a Plymouth
Re: Oil preassure gauge pipe location? [Re: fdwrench] #234038
02/12/12 05:26 AM
02/12/12 05:26 AM
Australia.
B
blueyAU Offline OP
blueyAU  Offline OP
B
Australia.
Hi there,
thanks for the feedback.
That looks just like the kit that I bought locally for $20-
its good value, even if you put it on the shelf for a while..
Peter
2 yy's u r
2 yy'u b
I C U R
2 yy's 4 me
Moderated by  32confederate
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
3 registered members (nhinchas, Rustoholic, pushrod), 7 guests, and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,518
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
