#232126 01/25/12 07:08 PM
Rivard Offline OP
I just looked at the oil pump and found no seal in it. What should be there. A felt seal or rubber or ? . Maybe I should say, I bought this car completely dis-assembled. The motor is in the frame but needs putting together. Is a complete gasket set going to give me all the gaskets and seals needed. I have all types of gasket material available to me and I can make most of what I need, or am I making my job harder by trying to do too much by trying to do it all myself?
Rivard #232134 01/25/12 08:08 PM
Your oil pump does not have a seal as such,but uses packing that is retained by the left hand threaded gland nut.The packing I use when making the oil pumps(either the 1924/25 or "490" type),
is called stern gland packing or greasy hemp.Other people use graphite coated asbestos rope,or something similar,but others may give their choice of gland packing.
:aust:
CJP'S 29
CJP'S 29 #232148 01/25/12 09:19 PM
Rivard Offline OP
Thanks for the help. Where I work they do have rope packing. I will check to see if it will work with oils.
