#232004 01/24/12 06:57 PM
Did Chevrolet dealers service individual wire ends? I know that most are available from different vendors. I have also wondered about the thick insulation that was used over the crimp of the connector as to how it was serviced. I have been using multiple layers of modern shrink tubing to make things look some better. The modern nylon coated terminals just don't do it for me.
Don
I use the modern terminals after removing the plastic/nylon junk they put on them. (Can't stand the blue). I then use the shrink tubing to finish off the joint at the terminal. Looks very good when finished.
devil Agrin
I do the same thing that Ray does. Makes a neater job.
Tiny #232034 01/24/12 10:03 PM
You can also buy the terminals without the plastic insulators. They are made for soldering and when shrink tubing is used the terminal ends look like factory.
Thats what I use.
Takes a little longer to solder and srink but its sure they stay good and look nicer too. luv2
Jianis
