Posts: 12 |
Friends, advise. I need to glue the rubber door seal. What should I use? What brand of glue?
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
3M SUPER WEATHERSTRIP AND GASKET ADHESIVE. I purchased mine at an Automotive Paint Store. It workde fine on the trunk seal of our 54.
Joined VCCA June 1, 1961
Posts: 12 |
Posts: 35 |
The yellow 3M adhesive is better than the black 3M adhesive. When I worked in the glass shop we only used the yellow--you have to be more careful with it, but it does stick better and last longer.
1953 Chevy 210 Convertible 1995 Dodge/Cummins Pickup
Posts: 29,847 |
Posts: 3,578 |
I had to remove the yellow stuff from my door and it was a mess,not to mention it does not blend with the color of the black weather strip and shows badly
Posts: 4,951 |
As I recall, I've only used weatherstrip adhesive on two cars. Both were BLACK. Weatherstrip was BLACK. Easy decision: I used BLACK 3M. Worked fine....that is held weatherstrip in place. The few places where there was a little excess could hardly be seen, even upon close examination.
Bill.
Posts: 1,740 Likes: 11
Posts: 1,740 Likes: 11 |
I guess I will give my 2 cents worth. When I ordered my weather seal for the '48 from Steele I ask which "glue" they recommend. The person taking my order told me that when they install weatherstrips "they" prefer the black 3-M (8008), so that is what I used. I had some of the yellow (8001) and also tried it. The 8008 worked FAR better, for me. One word of caution. The 8008 while works great, but, if you mess up or get some somewhere other than where you need, it is VERY difficult to remove once dry. The yellow , while it does not hold as well IS easier to remove.
Posts: 1,113 Likes: 1
Posts: 1,113 Likes: 1 |
Also not mentioned is the importance of having a "clean" surface before you apply the adhesive. On the metal, make sure you clean it with prep or lacquer thinner before applying the adhesive. Make sure your gasket is clean too, and apply a thin coating to the gasket, let it get tacky, then apply a second coat and press it on. This is what 3M recommends in their instructions.
Rick
Topics59,069
Posts429,047
Members18,308
