Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Adhesive for rubber. #231949
01/24/12 07:36 AM
01/24/12 07:36 AM
Russia SPb
R
Rustem Offline OP
Rustem  Offline OP
R
Russia SPb
Friends, advise. I need to glue the rubber door seal. What should I use? What brand of glue?
The Filling Station 1949-54
Re: Adhesive for rubber. [Re: Rustem] #231956
01/24/12 11:18 AM
01/24/12 11:18 AM
Dayton/Beavercreek, Ohio
B
Back Roads Offline
Back Roads  Offline
B
3M SUPER WEATHERSTRIP AND GASKET ADHESIVE. I purchased mine at an Automotive Paint Store. It workde fine on the trunk seal of our 54.
56 year member
Joined June 1961
Re: Adhesive for rubber. [Re: Back Roads] #231958
01/24/12 11:43 AM
01/24/12 11:43 AM
Russia SPb
R
Rustem Offline OP
Rustem  Offline OP
R
Russia SPb
Thank you!
Re: Adhesive for rubber. [Re: Rustem] #232417
01/28/12 05:36 AM
01/28/12 05:36 AM
L.A., Cal. & St. Louis, Mo.
R
rrausch Offline
rrausch  Offline
R
The yellow 3M adhesive is better than the black 3M adhesive. When I worked in the glass shop we only used the yellow--you have to be more careful with it, but it does stick better and last longer.
1953 Chevy 210 Convertible
1995 Dodge/Cummins Pickup
Re: Adhesive for rubber. [Re: rrausch] #232421
01/28/12 06:53 AM
01/28/12 06:53 AM
Eagle Point, Oregon
Junkyard Dog Offline
Eagle Point, Oregon
I use a lot of the 3M black adhesive. I found that it sticks a lot better and that it is more permanent and more durable than the yellow adhesive.
Re: Adhesive for rubber. [Re: Junkyard Dog] #232447
01/28/12 03:45 PM
01/28/12 03:45 PM
seattle,wa.
chef-chevy Offline
chef-chevy  Offline
seattle,wa.
I had to remove the yellow stuff from my door and it was a mess,not to mention it does not blend with the color of the black weather strip and shows badly
Re: Adhesive for rubber. [Re: chef-chevy] #232496
01/29/12 12:32 AM
01/29/12 12:32 AM
Portland, OR
42bill Offline
42bill  Offline
Portland, OR
As I recall, I've only used weatherstrip adhesive on two cars. Both were BLACK. Weatherstrip was BLACK. Easy decision: I used BLACK 3M. Worked fine....that is held weatherstrip in place. The few places where there was a little excess could hardly be seen, even upon close examination.
Bill.
Re: Adhesive for rubber. [Re: Rustem] #232533
01/29/12 03:16 AM
01/29/12 03:16 AM
GA.
ruscar Offline
ruscar  Offline
GA.
I guess I will give my 2 cents worth. When I ordered my weather seal for the '48 from Steele I ask which "glue" they recommend. The person taking my order told me that when they install weatherstrips "they" prefer the black 3-M (8008), so that is what I used. I had some of the yellow (8001) and also tried it. The 8008 worked FAR better, for me. One word of caution. The 8008 while works great, but, if you mess up or get some somewhere other than where you need, it is VERY difficult to remove once dry. The yellow , while it does not hold as well IS easier to remove.
Russell #38868
'48 4 door Fleetline
Re: Adhesive for rubber. [Re: ruscar] #232617
01/30/12 12:02 AM
01/30/12 12:02 AM
San Diego, CA
styleline51 Offline
styleline51  Offline
San Diego, CA
Also not mentioned is the importance of having a "clean" surface before you apply the adhesive. On the metal, make sure you clean it with prep or lacquer thinner before applying the adhesive. Make sure your gasket is clean too, and apply a thin coating to the gasket, let it get tacky, then apply a second coat and press it on. This is what 3M recommends in their instructions.
Rick
Moderated by  brewster
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
0 registered members (), 1 guest and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,511
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
